Full Dodo Juice Range Available @ WWW.VAGEN.VG
Shipping to the South of Ireland is set at a flat rate of £7.95 not matter how many items are ordered.
Dodo Juice Rainforest Rub £29.99
Dodo Juice Rain forest Rub (Soft wax). The Original Dodo Juice Soft Wax A high Carnauba car wax without the associated high prices.
Rain forest Rub provides the depth, warmth and durability of far more expensive brands.
Soft enough to apply by hand, Rain forest Rub contains Candelilla wax and beeswax and smells of fresh watermelon.
Key Ingredients: Carnauba Wax, Candelilla Wax Size: 250ml
Dodo Juice Purple Haze £32.99
"Dodo Purple" – a colour-charged soft wax for dark coloured cars.
As smooth as silk, Purple Haze has a voluptuous texture and gives outstanding results on darker coloured cars thanks to the addition of black montan wax.
One of the most sophisticated Dodo Juice waxes, with a fragrance of fresh lavender.
Key ingredients: Carnauba Wax, Montan Wax Available in: 250ml
Dodo Juice Orange Crush £32.99
Dodo Orange" – A 'Colour-Charged' Soft Wax For Warm Coloured Cars Orange oil suits a car wax perfectly, being a natural cleanser and one of the best smelling oils on the planet.
Blended with carnauba wax and yellow beeswax, it helps to create Orange Crush, a soft wax that breathes even more warmth into yellow, orange and red coloured cars.
Key Ingredients: Carnauba Wax, Yellow Beeswax, Orange Oil Size: 250ml
Dodo Juice Banana Armour £32.99
"Dodo Yellow" – A 'Colour-Charged' Hard Wax Banana Armour is a carnauba-based wax that spreads thinly before setting like stone.
Extremely impressive results, whether in terms of shine, beading or durability – and perfect for layering.
With yellow beeswax and banana oil. To be applied by foam applicator pad only.
Key Ingredients: Carnauba Wax, Yellow Beeswax, Banana Oil Size: 250ml
Dodo Juice Hard Candy (Hard Wax) £29.99
"Dodo Pink" - The 'Generic' Dodo Juice Hard Wax Like Rainforest Rub, Hard Candy contains candelilla wax as well as carnauba – but it’s hard in texture instead of soft.
This means it applies more consistently and sparingly, making it impossible to over-apply.
The result is perfect curing, time after time – a factor that helps boost durability.
Key ingredients: Carnauba Wax, Candelilla Wax Size: 250ml
Supernatural wax in wooden container 250ml £94.99
NEW - “Supernatural V.2” – The Superwax, Plain & Simple. In Stock Now - VERY LIMITED INITIAL SUPPLY The new super-premium wax from Dodo Juice, Supernatural has no added colourings or fragrances to make it as pure – and effective – as possible.
It comes in a specially commissioned air-tight container made from sustainable hardwood and hand-crafted in the UK.
Contains an enhanced amount of No.1 grade carnauba wax. Containers are refillable at additional cost when required.
Key ingredients: Carnauba Wax, Beeswax Size: 250ml
Dodo Juice Lime Prime (Pre-wax cleanser) 250ml £13.99
Dodo Juice Lime Prime (Pre-wax cleanser) 250ml Even More Of The Pre-Wax Cleanser From Dodo Juice.
Boasting unparalleled cleaning performance, class-leading ease of use and a prepared surface that shouts slickness and gloss.
Dodo Juice Lime Prime is a pre-wax cleanser formulated to clean, polish and prepare the paint surface ready for a layer of Dodo Juice carnauba wax.
* Micro-abrasives & cleaning agents remove paint oxidisation, ingrained dirt & light swirl marks
* Oils make the surface glossy & smooth, aiding subsequent wax application
* Stays wet for workability * Dries to a buffable haze after a short while If used on trim, test on a small unnoticeable area first. Size: 250ml
