IPB
Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> Codes And Clearing Them.
qawsed
post Jul 19 2010, 06:30 PM
Post #1
Member
Group: Members
Hi,
Got 2 codes today P3137 and P0642. Seems to be the swirl flap motor problem. I reset the codes and did the basic setting on vagcom, my question is if the codes stay off does that mean the problem is solved? ie will they reappear if its a permanent problem? Car runs 100%.
Anyone have the swirl flap motor problem?
Car is a 2.0 tfsi gti.
Go to the top of the page
+Quote Post
bearthebruce
post Jul 26 2010, 02:09 AM
Post #2
Member
Group: Members
QUOTE (qawsed @ Jul 19 2010, 02:30 PM) *
Hi,
If the problem continues, the codes will set again. You may have other codes. It appears you scanned the car with a generic OBD scanner. I would get your car scanned on a factory level scanner like VCDS (VAG-COM) because of the information noted in this article: Does an OBDII Scanner ...... Often the OBDII scan does not give all information.
- Bruce -
Ross-Tech, LLC
bruce@Ross-Tech.com
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Lo-Fi Version Time is now: 9th September 2010 - 07:31 PM
VAGdrivers.net 2005 - 2010  ·
