VAGDrivers.net VAGDrivers.net
Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> Mk2 Golf Gti Turbo, putting a turbo on a PB 1.8 8v gti engine
andycam08
post Oct 27 2009, 03:12 AM
Post #1
Newbie
Group: Members
Ive been looking at this for a while
i was looking at putting a turbo on my 8v gti pb engine
i seen this on ebay for a 2l 8v vw engine and was wondering if it would work
im not looking to get outragious bhp just a bit more
the car was running standered 111 bhp proven by joe power .Id now like to get it to 180 or 190 bhp
and was looking to see what else id need along with this kit to get it to this stage
i would like to keep the engine in it as to have something diffrent
and something thats fun to drive. As far as i can see i maybe wrong is that with this kit
runnig it at 8 psi boost i shouldnt have to change anything with the engine just bold on
and hook up and drive .... correct me if im wrong !!!!
The car already has !
superchipped ecu
g60 injectors
4branch manifold
plus the engine was only fully rebuilt 500 miles ago gaskets ect .......
http://cgi.ebay.com/ebaymotors/VW-85-86-87...013167008r20264
all advice welcome dont wanna jump in till ive all of the facts
Andy VW GTI Mad !!!!!
MK2 1.8 8v GTI
Go to the top of the page
+Quote Post
Razor
post Oct 27 2009, 08:41 AM
Post #2
Go Big Or Go Home
Group: Members
i think you can get a turbo kit from South Africa for the 8v
j-gti knows more
+Quote Post
Conor
post Oct 27 2009, 11:14 AM
Post #3
Advanced Member
Group: Members
If you buy that kit you're still going to have to change the engine management for a turbo setup. Just simply turning up the fuel pressure like they say isn't the way to do it. you're also going to have to lower the engines compression to run the turbo safely.
1991 MK2 Golf GTD - Members cars thread - SOLD
1989 MK2 Golf 16v Turbo - Members cars thread - SOLD
1983 Audi UR Quattro - Members cars thread
Midlands Volkswagen website - www.MLVW.ie
+Quote Post
turbosnow
post Oct 27 2009, 11:22 AM
Post #4
Adam S
Group: Members
Honestly although the price is good it looks like a hunk of crap...especially the turbo itself.
You could piece together a much better setup using decent parts for not that much more money.
In addition to what you have in this kit you would need either a chip programmed for boost (the superchip is not your friend here)or some sort of piggyback to control fueling, or Digi 1 (g60) engine managment, or a standalone system. The G60 injectors might get you by up to about 180hp but you would really want something bigger as the last thing you want on a turbocharged engine is to go lean.
Another thing to take into account when going turbocharged is that you will very likely get to the limits of your clutch and have to replace it with something stiffer.
Good luck, it is fun building something like this up the best way to do it IMO is to learn as much about it as possible before starting.
+Quote Post
Ray
post Oct 27 2009, 11:38 AM
Post #5
Advanced Member
Group: Members
Leon McSherry built an 8vT maybe 6 years ago , someone on here might be able to put you on to him. I've lost his number
+Quote Post
t.d
post Oct 27 2009, 11:53 AM
Post #6
Advanced Member
Group: Members
If I were you and I wanted that kind of power I would
a) Forget about putting a turbo on my own engine,
b ) Pick up a 1.8t conversion from a mk4 gti/ibiza cupra not a passat/a4 etc, or
c) Get a mk3 16v abf conversion and do a bit of work to it with cams exhaust and chip you will have 180+ bhp, or if you really want an 8vt
d) Get a pg g60 engine conversion ( everything minus the super charger) and put a turbo on that. This is what leon did to start with anyway. Pm davec for engines.
+Quote Post
Micksheen
post Oct 27 2009, 12:54 PM
Post #7
Group: Members
Option (d) sounds good above, a pg 8v engine should just drop in, plus its already built for boosting. Wiring should just plug in, and ther fuel system should be up for the job as well.
+Quote Post
turbosnow
post Oct 27 2009, 06:26 PM
Post #8
Adam S
Group: Members
QUOTE (Micksheenb @ Oct 27 2009, 12:54 PM) *
Yep the PB engine is definitely a better pick.
I have a PB block under an ABA crossflow head back home, but I don't think you guys got those heads here so a full PB swap is a good way to go.
I would suggest getting a specific chip for the g60 managment which is setup for a turbo rather than a supercharger, as there is a big difference in the way they boost.
Also again upgrading the injectors to match with the chip would be good as stock g60 injectors only flow about 270cc per minute and that's a bit low for a turbo if you want any more than about 155 hp.
+Quote Post
kjk
post Oct 27 2009, 09:54 PM
Post #9
Advanced Member
Group: Members
I have read on vortex lads running turbo on GTi 8v and the engine management (digi 2) seem to be able to cope with small boost up 0.5bar if i can recall correctly.
Just curious why you running the G60 chip?? G60 's has a map sensor rather than an airflow meter, just curious how that works out??
I Love Replica Wheels
+Quote Post
Micksheen
post Oct 27 2009, 09:57 PM
Post #10
Group: Members
Adam, isint a PB just a standard 8v engine?
+Quote Post
bri
post Oct 27 2009, 10:54 PM
Post #11
Advanced Member
Group: Members
QUOTE (Micksheenb @ Oct 27 2009, 09:57 PM) *
yeah it is, id say its a typo though, im sure he meant PG.
+Quote Post
turbosnow
post Oct 28 2009, 05:37 PM
Post #12
Adam S
Group: Members
QUOTE (bri @ Oct 27 2009, 10:54 PM) *
Yeppers...it is s typo was supposed to be PG...sorry lads.
+Quote Post
andycam08
post Nov 23 2009, 12:37 AM
Post #13
Newbie
Group: Members
ive done some research and found a pb engine 1.8 8v
runng
jetta dsl turbo and manifold from a 1.9 i think just say jetta dsl
turbo boosting +10 psi
2 headgaskets
g60 injectors
and a RRFPR ( rising rate fuel pressure regulator)
running on digi2 and putting out 180bhp
so i asume this can be done
unless someone can point me to a 20vt engine complete and some one willing to fit cheap??lol (IMG:style_emoticons/default/smile.gif)
MK2 1.8 8v GTI
+Quote Post
ventojetta
post Nov 23 2009, 01:28 AM
Post #14
Declan
Group: Members
QUOTE (andycam08 @ Nov 23 2009, 12:37 AM) *
runng
2 headgaskets
g60 injectors
Link?
+Quote Post
heartygti
post Nov 23 2009, 08:47 AM
Post #15
Advanced Member
Group: Members
did you even see how much it is to post that kit over here not cheap
94 fiesta 2.0 zetec
00 altezza rs200
93 golf gti black
92 golf gti mk3 (BREAKING)
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Lo-Fi Version Time is now: 27th March 2017 - 12:35 PM Privacy Statement
VAGdrivers.net 2005 - 2010  ·
