Tools needed
Allen keys
T55 star head bit to remove steering wheel
10/11 mm spanner
Good screwdriver set wit
Flat head with long shank
Philips small and medium long shank also
T20 star head screwdriver or similar
10 + 13 mm sockets ratchet + offset extension
Jewellers screw drivers
Insulating tape
Pliers
Sharp knife
Some cable ties
A good light
Something to kneel on e.g. a piece of heavy cardboard etc
Installation instructions for retrofitting a cruise control regulator in the Golf IV / Golf IV Variant TDI / petrol engine with electronic throttle control (E-Gas), Bora / Bora Variant TDI / petrol engine with electronic throttle control (E-Gas)
SEK-0354
Note:
Due to the safety regulations which apply to the handling of airbag components, this retrofit can only be installed by partner dealerships of Volkswagen AG. Coding in the engine control unit is also required. These activities should be carried out only in a partner dealership of Volkswagen AG.
VW-Nr. 1J0012175A
EBK-0111
Contents of the service kit:
1 steering column switch (directional indicator switch with switch for CCS)
1 wiring harness for CCS (interior)
2 wiring harness for CCS 1 installation description
Special tools, workshop equipment, test and measuring equipment and accessories required
• Repair Manual "Body Installation Work, Interior"
• Repair manual "Electrical System"
• Folder Current Flow Diagrams, Electrical Fault Finding and Fitting Locations
• V.A.G 1332 Torque spanner (40 - 200 Nm)
• VAS 5051/B, VAS 5052 Vehicle Diagnosis, Measuring and Information System
• VAS 5053 Vehicle Diagnostic System
• VAS 1978 Wiring Harness Repair Set
Proceed as follows:
• First, disconnect the battery ground cable.
Notes:
• Please obtain the radio code before disconnecting the battery.
• For the following steps, it is essential that you follow the repair manual Body Installation Work, Interior in Chapter 69.
-2-
Important!
Work on the airbag system may be carried out only be trained specialists. The relevant safety requirements must be observed, see Safety Notes on the Airbag in the Repair Manual (Chapter 69).
SEK-0340
Release the steering column adjusting mechanism.
Pull the steering wheel -1- out and push it into the upper position.
Secure the steering column adjusting mechanism.
Turn the steering wheel -1- until the spoke of the steering wheel is vertical.
Insert an approx. 175 mm long screwdriver into the hole in the steering wheel retainer from the rear (insert screwdriver about 45 mm).
Push the screwdriver upwards Arrow. This pushes the securing clamp -6-backwards and releases the snap hook -3- on the airbag -4-.
- Use the same procedure to release the hook on the other side.
- Disconnect the plug connection -2- on the airbag -4- and set it aside carefully.
- Turn the steering wheel -1- to the centre position (wheels are pointed straight ahead).
- Remove the attachment screw -5-.
- Pull the steering wheel off of the steering column.
SEK-0340
-3-
Notes:
• The multipoint socket screw is treated with a sealant, and can be used up to five times.
• Make a punch mark after each time it is installed.
• Tightening torque 60 Nm, see repair manual.
Remove the attachment screws -2-, -3- and -4- on the trim of the steering column switch.
Remove the attachment screws -1-from the handle of the steering column adjusting mechanism.
Pull off the handle and remove the lower trim for the steering column switch.
- Pull the upper trim -1- in
- the direction of the arrow A -. Now remove the trim top -2- in
- the direction of the arrow B - from the top.
-4-
Disconnect the plug connection -1- to the reset ring with slip ring.
Release the securing clamps -arrows-on the reset ring with slip ring and pull it off.
Note:
The reset ring with slip ring -F138- must not be rotated out of the centre position (secure with adhesive tape if necessary).
- Slacken the clamping screw for the steering column switch.
- Pull the steering column switch forwards slightly.
- Disconnect all of the plug connections to the steering column switch and remove it.
- Remove the steering column switch.
Release the locking lug on the steering column switch with a screwdriver (see illustration).
Pull the directional indicator switch off of the windshield wiper switch.
Replace the directional indicator switch using the directional indicator switch with CCS contained in the service kit.
SEK-0003
-5-
4 3
SEK0349
- Unclip the left-hand trim from the fuse holder on the dashboard.
- Remove the attachment screws -4-.
- Unclip the left-hand trim -1- all the way.
- Remove that attachment screws -3-and unclip the right-hand trim -2-.
- Reinstall the steering column switch.
- Connect the CCS wiring harness to the directional indicator switch and fasten the wiring harness to the existing cable harness.
- Route the new wiring harness from the directional indicator switch to the central electric system in the footwell.
- Fasten the wiring harness with cable clips.
SEK-0359
Release the fixing nuts -arrows- and remove the relay board -1- together with the relay plate; if necessary also release the lower screwed connections on the relay plate.
-6-
Lever the caps -arrows-off of the wiper rod with a suitable screwdriver.
Remove the fixing nuts of the wiper arms and remove the wiper arms.
- Pull off the rubber seal -1-.
- For vehicles up to model year 1999, remove the attachment screws -2-, see Repair Manual "Electrical System".
- Remove the cover from the pollen filter.
- Unclip the trim on both sides from the fender inner.
- Carefully press the cowl upwards and out.
- Disconnect the connecting plug on the wiper motor.
- Remove the attachment screws (M6) -arrows- and take off the washers.
- Remove the wiper frame together with the wiper motor.
-7-
Remove the cover on the electrical box in the reservoir.
Separate the black 10-pin connector (T10e)-arrow-.
- Release the 10-pin connector (T10e) -arrow- from the bracket.
• Pull the 10-pin connector (T10e) -2-through to the footwell.
Release the lock -1- from the 10-pin connector (T10e) -2-.
-8-
EBK-0097
Insert the individual connecting connecting cables (with labelled tags) of the wiring harness -2- into the corresponding chambers of the connector housing -1-.
Refasten the lock on the connector housing.
Vehicles with petrol engine (excluding engine code letters APF, AQN, AQP, AUE, AVU, BDE, BEH, BFH, BML)
Release the lock -arrow A- of the 10-pin connector (T1 Oe) on the engine compartment side and slide the lock in the direction of -arrow B-.
Insert the individual connecting wires of the supplied wiring harness (80-pole engine control unit wiring harness 1J0.971.425.B,121-pole engine control unit wiring harness 1J0.971.425.C) into the chambers in the connector housing T1 Oe according to the following list: T10e/1 blue/grey T10e/2 red/yellow T10e/3 black/white T10e/9 white
Engage the connector housing lock
again.
Engage the plug (T10e) in the
electrical box and connect the mating
connector.
Fit the cover on the electrical box.
Next run the wiring harness to the
engine control unit in the plenum
chamber. Use cable ties to secure the
wiring harness to the existing engine
wiring harness.
-9-
B
Vehicles with 80-pole engine control unit (engine code letters APE, AXP, BCA)
- Disconnect the 52-pin plug for the remaining engine wiring from the engine control unit.
- Separate the cable tie -1-.
- Press together the cover in the area of -arrow B- and fold the cover open in the direction of -arrow A-.
- Use a suitable screwdriver to press the locks -1- and -2- in the direction of the arrow.
- 2
- Remove the seal -1- using a suitable ejector tool from the Wiring Harness Repair Set -1978- in accordance with the listing on page 12.
-10-
Vehicles with 121-pole engine control unit
- Disconnect the plug of the 81-pole remaining engine wiring harness from the engine control unit.
- Pull out the locking device -1- of the plug in the direction of-arrow A-.
- Pull out the locking device -2- in the direction of-arrow B-.
- Next remove both plug boards from the connector housing.
EBK-0011
MTODDDDQDDDQDnDQDQQDQ
s
- Remove the plug contacts using a suitable ejector tool from the Wiring Harness Repair Set -1978- in accordance with the listing on page 12.
-11-
-12-
Connect the wires to the free pins on
the connector for the remaining engine
wiring harness in accordance with the
listing below.
Engine code letters: BAD
T121/49 blue/grey
T121/51 red/yellow
T121/55 black/white
T121/52 white
Engine code letters: BFQ T121/67 blue/grey T121/66 red/yellow T121/69 black/white T121/68 white
Engine code letters: APE, AXP, BCA T80/39 blue/grey T80/25 red/yellow T80/24 black/white T80/50 white
Engine code letters: ARZ, ATM, AUM, AUQ, AUS, AZD, AZH, AZJ, BCB T121/75 blue/grey T121/57 red/yellow T121/38 black/white T121/76 white
Plug assembly for the remaining engine wiring harness is carried out in reverse sequence.
Vehicles with petrol engine or diesel engine
- Remove the attachment screws -C-from the fuse holder.
- Press the locking devices -B- and pull the fuse holder -A- into the footwell.
- Pull fuse -5- out of the fuse holder.
- On the rear, release the cable -arrow-leading out of fuse chamber 5 using the stripping tool VAS 1978/4. Clip the cable into the individual connector housing of the CCS wiring harness.
- Connect the short connecting cable (black/blue) -arrow- from wiring harness for CSS to fuse chamber -5-
-13-
Clip cable -2- together with connector into the connector housing -1-.
Re-insert fuse -5- and install fuse holder.
Secure loose wiring harnesses with appropriate cable clips.
Further assembly is carried out in reverse sequence. Please observe the following notes:
Notes:
• It must be ensured that the distance between the steering wheel and the reset ring is at least 3 mm.
• The markings -A- and -B- on the steering column and steering wheel must be in alignment.
• The attachment screw for, the steering wheel is treated with a sealant, and can be used up to five times.
• Make a punch mark on the attachment screw after each time it is installed.
Important!
Before connecting the battery,
observe the following safety
regulations:
- There must be no persons in the vehicle
- Switch on ignition
- Close doors
- Connect battery
Note:
After the engine control unit has been coded, a test drive must be carried out to check that the CCS is functioning properly (e.g. check that*>the CCS switches off when the clutch pedal or brake pedal is pressed).
Allen keys
10/11 mm spanner
Insulating tape
Pliers
Sharp knife
Some cable ties
A good light
SEK-0354
Note:
VW-Nr. 1J0012175A
EBK-0111
Proceed as follows:
Notes:
-2-
Important!
SEK-0340
SEK-0340
-3-
Notes:
-4-
Note:
SEK-0003
-5-
4 3
SEK0349
SEK-0359
-6-
-7-
-8-
EBK-0097
again.
connector.
wiring harness.
-9-
B
- 2
-10-
EBK-0011
s
-11-
-12-
listing below.
T121/49 blue/grey
T121/51 red/yellow
T121/55 black/white
T121/52 white
-13-
Notes:
Important!
regulations:
- Close doors
- Connect battery
Note:
