VAGDrivers.net VAGDrivers.net
Welcome Guest ( Log In | Register )
VW Parts at Andy's
2 Pages V   1 2 >
Reply to this topicStart new topic
> New Shape Passat Parking Brake Problem
Trevor
post Oct 21 2008, 08:19 PM
Post #1
Advanced Member
Group: Root Admin
Our 06 Passat arrived home tonight with this problem:
Tuesday,21,October,2008,21:16:57:40933
VCDS Version: Release 805.0
Address 53: Parking Brake
Control Module Part Number: 3C0 907 801 B
Component and/or Version: EPB VC8HC001 013 0001
Software Coding: 0000011
Work Shop Code: WSC 00028
Fault Codes have been Erased
1 Fault Found:
02443 - Control Head
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 55744 km
Time Indication: 0
Date: 2000.00.00
Time: 08:32:09
Freeze Frame:
Voltage: 14.29 V
Count: 46
Can't get it to clear. Any ideas?
Go to the top of the page
+Quote Post
Ray
post Oct 21 2008, 08:26 PM
Post #2
Very Big Member
Group: Members
Probably of no use to you but i hired a passat in cyprus last christmas , it locked up the handbrake when i stopped and would not release it. I disconnected the battery for 20 mins and it was fine after that but didnt have it scanned to see if the fault codes were cleared for obvious reasons
QUOTE (Knob-Jockey @ Feb 16 2012, 02:28 PM) *
in my eyes the 1.9 sport is like a type r kitted 1.4 civic you either have the real thing or you dont
+Quote Post
Trevor
post Oct 21 2008, 08:29 PM
Post #3
Advanced Member
Group: Root Admin
Thanks Ray. Just onto EoinO from Ardfallen Motors. He told me do the same. So going to disconnect it now and see.
+Quote Post
Geo
post Oct 21 2008, 08:33 PM
Post #4
Advanced Member
Group: Members
Disconnect it and hold the terminals together for about 30 seconds.
After that I'd be all out of ideas I know nothing about the new shape Passats (IMG:style_emoticons/default/biggrin.gif)
+Quote Post
Trevor
post Oct 21 2008, 09:21 PM
Post #5
Advanced Member
Group: Root Admin
Left the battery disconnected for 30 minutes. Reconnected and the light were still on the dash flashing.
After about 30 seconds they went off but then got another couple of lights.
Parking brake was now functioning but the ESP was showing as off and could not switch it back on.
Scanned it again.
Address 03: ABS Brakes Labels: 3C0-614-095.lbl
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667156106
Coding: 0013569
Shop #: WSC 00028 028 00001
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Shop #: WSC 00000 000 00000
1 Fault Found:
000 - -
Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
4 Faults Found:
02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 27
Mileage: 55776 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
Freeze Frame:
Voltage: 8.90 V
Count: 205
02428 - Left Parking Brake Motor (V282) Clamping Force Not Reached
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 27
Mileage: 55776 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
Freeze Frame:
Voltage: 8.90 V
Count: 204
01487 - System Function Test
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 27
Mileage: 55776 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
Freeze Frame:
Voltage: 11.90 V
Count: 160
Freeze Frame:
Fault Status: 00111000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 27
Mileage: 55744 km
Time Indication: 0
Date: 2000.00.00
Time: 08:32:09
Freeze Frame:
Voltage: 14.29 V
Count: 46
+Quote Post
Declan
post Oct 21 2008, 09:25 PM
Post #6
www.autostadt.ie
Group: Members
COuld the rear pads be worn to far and the brakes not getting enough bind as far as the ECU is concerned Trevor ?
Theres a process to reset the park brake settings after inserting new pads - might be worth running to reset pad position ?
That right to drive module is going to be a right pain in the arse.
+Quote Post
Trevor
post Oct 21 2008, 09:27 PM
Post #7
Advanced Member
Group: Root Admin
Ok went for a quick spin and lights gone out.
Going to scan it again.
+Quote Post
Trevor
post Oct 21 2008, 09:41 PM
Post #8
Advanced Member
Group: Root Admin
OK all fine.
So the solution for those of you with Passat handbrake problems is to disconnect the battery for 20-30 minutes (IMG:style_emoticons/default/laugh.gif)
Thanks for the suggestions/help.
+Quote Post
Trevor
post Oct 21 2008, 09:42 PM
Post #9
Advanced Member
Group: Root Admin
QUOTE (Declan @ Oct 21 2008, 10:25 PM) *
Plenty of meat on the pads Declan.
+Quote Post
Ray
post Oct 21 2008, 09:59 PM
Post #10
Very Big Member
Group: Members
Buy a 3BG Trevor (IMG:style_emoticons/default/laugh.gif) Good that it's all sorted
+Quote Post
JK1
post Oct 21 2008, 10:23 PM
Post #11
Newbie
Group: Members
QUOTE (Ray @ Oct 21 2008, 10:59 PM) *
Hi Trevor,
Sorry to burst your bubble but you have not seen the last of your problems.
This is a common problem.
Only fix is a software update and new Park brake switch.
You will possibly get it under warranty. If not it is one hour labour.
Call Ken in Blackwater motors. He will look after you and if it can be done under warranty he will do it.
I have seen 5 passats with this issue this year.
Very easy to get the light off and codes cleared but they return always without the updated firmware.
Best regards
JK
+Quote Post
Trevor
post Oct 22 2008, 07:48 AM
Post #12
Advanced Member
Group: Root Admin
Thanks JK.
Yeah I realise that I only sorted the issue not the problem.
Ardfallen did mention a new switch may be needed so I'll follow up with VW and see can I get it and the firmware update done under "goodwill".
First time it happened in 2 1/2 years. Actually car has been troublefree up to now.
+Quote Post
JK1
post Oct 22 2008, 09:53 AM
Post #13
Newbie
Group: Members
QUOTE (Trevor @ Oct 22 2008, 08:48 AM) *
Thanks JK.
Hi Trevor.
Strangely It seems to be affect them now.
Make sure that they do not charge you over the hour as the last few I have sent in to Blackwater thats what it has taken but as I said they have covered a few under warranty.
Best regards
JK
+Quote Post
Trevor
post Jan 22 2009, 03:29 PM
Post #14
Advanced Member
Group: Root Admin
Well we had this problem again yesterday.
I made enquiries locally and was quoted €600 to fix by a main VW service agent (IMG:style_emoticons/default/laugh.gif)
Gave Ken @Blackwater a ring. About 95 euro he said which includes a new switch and firmware upgrade. Thanks JK.
+Quote Post
skibum
post Jan 22 2009, 03:48 PM
Post #15
Advanced Member
Group: Members
QUOTE (Trevor @ Jan 22 2009, 03:29 PM) *
€505 difference, jeasus........ (IMG:style_emoticons/default/blink.gif)
MK1 Golf 1.1 Rust Bucket Gone....
Transporter T4 1.9 D Gone
MK2 1.8 GL Gone
Corrado 1.8 16V Gone
MK2 1.8 GTI 8V Gone
Caddy 1.9 TDI Gone
1990 £50 Nissan Micra !!! Gone :)
MK2 1.6D X 2 Both Gone :(
MK3 1.9TDI, G60 brakes, G60 steelies!! Gone :(
2003 Passat TDI :)
A good friend would drive 30 miles at 2:00 am to bail you out of jail.
A best friend, however, would be sitting in the cell next to you saying "Man, that was F'n Awesome!"
+Quote Post
liamO
post Jan 22 2009, 04:28 PM
Post #16
Advanced Member
Group: Members
Ken is always very helpful for this kind of stuff .
Would the other garage be the one that has my surname ?
+Quote Post
Declan
post Jan 22 2009, 04:33 PM
Post #17
www.autostadt.ie
Group: Members
Theres's hardly a garage called "The langer" motors is there (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
+Quote Post
liamO
post Jan 22 2009, 06:39 PM
Post #18
Advanced Member
Group: Members
QUOTE (Declan @ Jan 22 2009, 04:33 PM) *
You would be surprised what we have in" Dirty mullah farmer" yards down here ! (IMG:style_emoticons/default/laugh.gif)
+Quote Post
Oakgreen
post Jan 22 2009, 06:42 PM
Post #19
Advanced Member
Group: Members
handbrake switch is a very common problem on the new passats.
+Quote Post
Trevor
post Jan 22 2009, 08:12 PM
Post #20
Advanced Member
Group: Root Admin
No its an authorised VW repair and service centre (IMG:style_emoticons/default/wink.gif)
+Quote Post
2 Pages V   1 2 >
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Lo-Fi Version Time is now: 23rd May 2013 - 06:21 AM
VAGdrivers.net 2005 - 2010  ·
